Date/Time: Sun, 24 Nov 2024 13:39:52 +0000
TRADING IN SIERRA CHART
View Count: 307
[2024-05-27 08:28:39] |
DMK - Posts: 15 |
Hello I have opened an account through AMP FUTURES in CQG DATA FEED Can you please guide me with the process of the service package as I want CME, NYMEX, and COMEX data? Thank you |
[2024-05-27 14:41:20] |
Sierra_Chart Engineering - Posts: 17156 |
You really should use Teton order routing instead of CQG. AMP supports Teton order routing: Sierra Chart Teton Futures Order Routing: Setup Instructions You need to purchase usage time as explained here: Sierra Chart Purchase and License Information: Renewing Access And to activate the exchanges you need, refer to: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-28 06:04:44] |
DMK - Posts: 15 |
Hello I would like to go ahead with CQG So, kindly, can you tell me which service package should I go with? When I asked AMP Futures, they told me to go with the denali feed Can you please confirm and get back? Thank you |
[2024-05-29 08:40:37] |
DMK - Posts: 15 |
[2024-05-29 11:11:35] |
DMK - Posts: 15 |
Dear, I hope this email finds you well. I am writing to express my intention to proceed with CQG services. However, I am seeking guidance on which service package would be most suitable for my needs. I have been advised by AMP Futures to consider the Denali feed. Could you kindly confirm if this recommendation aligns with your expertise and provide any additional insights or recommendations regarding the available service packages? Your assistance in this matter would be greatly appreciated. I look forward to your prompt response. Thank you for your attention. Warm regards, |
[2024-05-29 13:57:06] |
You will need Service Package 10 or 11. The differences are described here: Description of Service Packages and Pricing And you will need to activate the Denali Data Feed. Here are instructions for that: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* And below are instructions for adding usage time: ----- Follow these instructions to add usage time to your Sierra Chart account: 1. Select "Help >> Account Control Panel" on the Sierra Chart software menu. On the displayed webpage, click on "Activate Services". Or you can also go to this page in your browser: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Login with your Sierra Chart Account Name and Password if necessary. 2. Choose the particular Service Package and the number of Months that you want and press the "Update/Set" button. If you are on a Trial, you will first need to add sufficient credit to your account to pay for the chosen Service Package/Months. In this case, refer to the step below. Once that is done you can then choose the Service Package and number of Months. 3. Add sufficient credit to your Services Balance using any of the available payment options: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For further information, refer to: Sierra Chart Purchase and License Information: Renewing Access ---- CQG set up instructions: CQG Trading Platform Service: Setup Instructions You should really be aware, of the huge beneficial advantages to using Teton versus CQG: Sierra Chart Teton Futures Order Routing: Introduction Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-05-29 13:57:40
