Date/Time: Sun, 24 Nov 2024 13:05:25 +0000
How to identify which alert number is what alert when using spreadsheet
View Count: 174
[2024-05-27 07:06:23] |
AzharBasri - Posts: 28 |
Hi, I'm generating alerts from spreadsheet and want to know which alerts is which since I want to use chat for remote alert notifications by integrating telegram. For example I want to send the alerts once K column triggered and send the message to telegram. Can I set the alert number to any particular alert generated from TRUE condition in columns from spreadsheet, and of yes, how can I do that? Thanks |
[2024-05-27 14:30:11] |
Sierra_Chart Engineering - Posts: 17154 |
You can see what Alert Number is associated with an alert looking at the Alerts Log: Alerts Manager To configure what Alert Number is used for a particular Sheet column, use these Inputs: Spreadsheet Systems, Alerts and Automated Trading: Column [K, L, M, N, O, P, Q, R, S, T, U, V-Z] Alert Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
