Date/Time: Sun, 24 Nov 2024 12:45:48 +0000
Can't see BUY orders on Trading Chart DOM
View Count: 159
[2024-05-27 07:02:16] |
User629461 - Posts: 179 |
Hi, I don't know what I've done but I can't see the orders on the BUY column of the Trading Chart DOM for a particular chart. Its visible on the other charts so I must have done something. Where is this setting located? See pic attached. https://www.sierrachart.com/image.php?Image=1716793295677.png |
[2024-05-27 14:24:47] |
Sierra_Chart Engineering - Posts: 17154 |
First thing to do is to refer to the information here: File Menu: Not Receiving the Full Number of Market Depth Levels And then here: Chart Trading and the Chart DOM: Displaying Market Depth Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
