Date/Time: Sun, 24 Nov 2024 13:01:06 +0000
How to use GDI to draw text with transparent background?
View Count: 226
[2024-05-26 22:43:39]
User719512 - Posts: 263
Should you be able to specify a NULL background?
sc.Graphics.DrawTextAt(msg, x_coordinate, y_coordinate);
Also, does the sc.Graphics.SetTextColor support setting an Alpha value?
// nothing like this seems to have an effect
sc.Graphics.ResetBackgroundColor();
sc.Graphics.ResetBackgroundMode();
n_ACSIL::s_GraphicsPen nullPen;
nullPen.m_PenStyle = n_ACSIL::s_GraphicsPen::e_PenStyle::PEN_STYLE_NULL;
sc.Graphics.SetPen(nullPen);
n_ACSIL::s_GraphicsBrush nullBrush;
nullBrush.m_BrushType = n_ACSIL::s_GraphicsBrush::BRUSH_TYPE_STOCK;
nullBrush.m_BrushStockType = NULL_BRUSH;
sc.Graphics.SetBrush(nullBrush);
GraphicsColor_Foreground.Color.RGB.Alpha = 128;
GraphicsColor_Foreground.Color.RGB.Red = 0;
GraphicsColor_Foreground.Color.RGB.Green = 128;
GraphicsColor_Foreground.Color.RGB.Blue = 0;
sc.Graphics.SetTextColor(GraphicsColor_Foreground);
[2024-05-27 10:01:02]
User431178 - Posts: 541
sc.Graphics.SetBackgroundMode(TRANSPARENT);
[2024-05-27 14:20:59]
Sierra_Chart Engineering - Posts: 17154
Yes this is correct:
No:
