Date/Time: Sun, 08 Sep 2024 03:04:40 +0000
[User Discussion] - Trading Micro Dax Futures
View Count: 180
[2024-05-25 19:52:45] |
kam2001 - Posts: 79 |
Hi, i want to explore trading Micro Dax Futures, so just after some advise as where to start, i heard about Teton Order Routing with Sierra Chart, which i can look into but is it available for Eurex exchange ? Do i need a separate broker or clearing firm or Sierra Chart also act as broker? any suggestions/recommendations on Broker (United Kingdom) to get me started would help. Thanks. Date Time Of Last Edit: 2024-05-25 20:51:55
[2024-07-08 19:02:02] |
Sierra_Chart Engineering - Posts: 16292 |
Teton order routing does not support EUREX trading. You would have to use CQG or Interactive Brokers. More information about them can be found here: https://www.sierrachart.com/index.php?page=doc/Contents.php#SupportedDataAndTradingServices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
