Date/Time: Sun, 24 Nov 2024 12:42:13 +0000
Market Depth Data
View Count: 251
[2024-05-25 14:38:56] |
User338118 - Posts: 11 |
I am trying to replay past historical chart data and my market depth data shows as the following: https://www.sierrachart.com/image.php?Image=1716647742470.png How do I make it show more than a total of 1 data? Will I need a specific data feed even for replaying past charts |
[2024-05-25 23:52:37] |
Update: I can access and see the dom when using sierra chart backtest trade data replay; however, during live market hours or using replay chart it does not show market depth data.
[2024-05-27 20:39:55] |
Sierra_Chart Engineering - Posts: 17154 |
There is no market depth data for US equities symbols unless you use NASDAQ TotalView symbols: Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
