Date/Time: Sun, 24 Nov 2024 13:03:31 +0000
Drawing style for dual bars one on left and one right side?
View Count: 195
[2024-05-25 13:19:11] |
TopGunTrader - Posts: 172 |
Hi, I want to create for example bid volume on left and ask on right under each bar. Is there a way to have side by side bar's or something similar red/green so I can see buying/selling changes over time. I've looked many times but can't find this. If not any way to create Bar align left, Bar align right there are so many ways this is useful showing bids for 10 levels on left and ask on right to see limit order book intuitively and clean. Thanks |
[2024-05-27 20:55:18] |
Sierra_Chart Engineering - Posts: 17154 |
Have a look at this Subgraph Draw Style (DRAWSTYLE_CUSTOM_VALUE_AT_Y: ) which supports custom alignment: ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].DrawStyle And you can also control the color of the text individually at each chart bar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-05-27 20:55:28
