Date/Time: Sun, 24 Nov 2024 11:30:08 +0000
MSCI China A50 Connect Index
View Count: 426
[2024-05-25 02:13:26] |
User169391 - Posts: 62 |
HI, In the find a symbol list for the MSCI China A50 Connect Index(under futures) the symbol is given as HCA-202405-HKFE-USD-25. I use interactive brokers and the symbol used is MCA-202405-HKFE-USD-25(the M being substituted for the H). Can this be added to the list and I am assumiing will pick up the contract specs? Or is this another interactive thing. |
[2024-05-27 16:59:15] |
Sierra_Chart Engineering - Posts: 17154 |
We want you to manually specify the symbol. We will not be adding a new symbol unless we get a link to the Interactive Brokers Symbol Specifications for the symbol. You can manually specify symbols: Interactive Brokers Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-28 23:34:59] |
please see attached file
MCA 2024-05-29 091814.png / V - Attached On 2024-05-28 23:31:54 UTC - Size: 41.25 KB - 62 views Attachment Deleted. |
[2024-05-31 19:57:13] |
Ok we will set this up.
[2024-06-01 16:08:05] |
This symbol has been added but we are not sure we have correct settings like the Tick Size or Currency Value Per Tick. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-06-01 16:08:33
[2024-06-02 22:59:56] |
Where is this to be found in the symbol list? I cannot see it. Done the update from the server and disconnect/ reconnect. thanks |
[2024-06-03 00:34:04] |
It is listed in File >> Find Symbol >> Futures.
