Date/Time: Sun, 24 Nov 2024 13:31:30 +0000
just switched from ninja to sierra with rythmic... could someone help out with below?
View Count: 212
[2024-05-24 18:59:31]
alexkim1211 - Posts: 9
1. How do I invert the Price axis when zooming out. in other words when i put mouse pointer on price axis and move up it zooms in... how do i invert that?
2. how do i activate max loss shut down for apex 20 accounts.
3. how do i just get CVD just for NQ in 1 chart 22r. i dont wanna see NQ at all. just teh CVD
4. I have this Levels column next to Price column in chart... how do i get rid of that?
5. My trade window keeps blinking when set to chart... how i fix this?
6. I have trade alerts for all 20 accounts through apex going off... how do i fix this?
[2024-05-24 20:57:15]
1. Refer to the following:
General Settings Window: Interactive Scale Range Movement Adjust Direction (Global Settings >> General Settings >> Charts >> Charts)
2. Refer to the Global Profit/Loss functionality, but it needs to be setup for each account. It does not have a tie to the "Order Allocation to Trade Accounts":
Global Profit/Loss Management
3. Enable the option (place a checkmark) for "Display as Main Price Graph" for the study you want to view as the main price graph. Refer to the following:
Chart Studies: Settings and Inputs Tab >> Display As Main Price Graph
4. When "Trade >> Trading DOM On" is enabled, then there are going to be "Buy" and "Sell" or "Buy/Bid" and "Sell/Ask" columns displayed. You can control what is controlled by adjusting the columns. Refer to the following:
Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific)
If you do not want to see either the Buy or Bid (Sell or Ask) columns at all, then turn off "Trade >> Trading DOM On" and instead use "Trade >> Show Market Data Columns".
Trade Menu: Show Market Data Columns (Trade menu)
5. Do you mean it is blinking when the Trade Window is attached to a chart? There should not be any blinking. What kind of blinking is occurring and does it happen only when you are doing something in the chart, and if so, what is that?
6. What do you want to happen? If you do not want any alerts, then adjust the settings starting at the following:
Global Trade Settings Windows: Play Alert For New Order (Global Settings >> General Trade Settings >> Notifications)
