Date/Time: Sun, 24 Nov 2024 13:22:56 +0000
I want the crosshairs to move the chart also
View Count: 194
[2024-05-24 15:37:35] |
JoeThanksG - Posts: 6 |
Question Where can I go to make a suggestion I know you guys are programmers Like: making the crosshairs move the chart also, like TradingView or QuanTower or Jigsaw charts which suck that's why I am here, their DOM is excellent it's a pain in the rear to have to be going back and forth from crosshairs to hand |
[2024-05-24 18:40:09] |
VLiviu - Posts: 223 |
See attached. Make sure it's the same then select hand and drag the chart |
Screenshot 2024-05-24 143909.png / V - Attached On 2024-05-24 18:39:44 UTC - Size: 33.47 KB - 49 views |
[2024-05-24 20:07:38] |
The important item from what VLiviu shows is the setting for "Action when Other Tools Selected". Refer to the following: Chart Drawing Tools: Action When Other Tools Selected (Global Settings >> Tool Settings >> Chart Values >> Chart Values) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
