Date/Time: Sun, 24 Nov 2024 13:57:30 +0000
Data Question
View Count: 179
[2024-05-24 14:37:20]
User749040 - Posts: 37
Hello, I have Teton and prop accounts with Rithmic. As far as I can tell, whatever the main instance runs in terms of data, sub instances follow. So if I have Rithmic on the main I will have Rithmic on all sub instances.
In order to have a version of Sierra with Teton up and running and Rithmic at the same time I need to have another installation of Sierra running. Not a new instance but a whole new installation in which I can run the other data. Is that correct?
[2024-05-24 15:21:00]
Yes, you have your information correct.
Refer to the following for how to install a second Sierra Chart:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
[2024-05-24 15:26:36]
Thank you, as far as the data that's shown for example in the footprint, I'm still getting Denali Data as I have "Allow Support for Sierra Chart Data Feeds" set to "Yes" even tho I'm connected to Rithmic, correct?
[2024-05-24 19:47:56]
Yes, this correct. One way to tell is look for an "[M]" after the symbol in the Chart Header in the main instance (it will not be there in sub-instances). That indicates that you are getting the data from us.
