Date/Time: Sun, 24 Nov 2024 13:45:21 +0000
ryhtmic issue
View Count: 185
[2024-05-24 12:11:27] |
User992336 - Posts: 7 |
hello , i 'm using rythmic in apex with NQ and i'm using copy trading with sierra between 2 acounts and i received lot of time errors messages from logs can u help me if it there an issue with something because its very disabling thank you |
[2024-05-24 15:06:08] |
The only help we can give you with this is to ensure that you do not have any symbols that are not formatted for Rithmic (or that Rithmic would/can not deal with). The list of places to check for symbols is at the following link: Chart Data and Chart Data Files: Cleaning Up Old and Unused Symbols for Efficiency For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
