Date/Time: Sun, 24 Nov 2024 13:59:38 +0000
installation of update failed (using macbook air with crossover)
View Count: 169
[2024-05-24 09:22:44]
AlanP - Posts: 5
I have tried several times to install update 2642.
the last message i got was that the update had failed.
the log has been sent and i followed instructions to send this message.
Any help would be appreciated
[2024-05-24 14:49:02]
In your case, for some reason it had trouble downloading the file and eventually timed out.
Please use the Zip installer instead. Refer to the following:
Software Download: Sierra Chart Zip Installer
