Date/Time: Sun, 24 Nov 2024 14:01:41 +0000
Showing Ask/Bid Volume Difference Split in Numbers Bars
View Count: 210
[2024-05-24 08:57:29]
mandano89 - Posts: 24
Is it possible to make the Ask/Bid Volume Difference showing like in the picture with the numbers in the middle, positive bars go right and negative bars go left? I know there is a possibility to show the Ask/Bid Volume Split Profile but I haven't find a way to do the same for the Ask Bid Volume Difference.
imageAskBid_Split_Volume_Difference.PNG / V - Attached On 2024-05-24 08:57:09 UTC - Size: 32.46 KB - 54 views
[2024-05-24 14:46:11]
There is not an option to show the Ask/Bid Difference profile with right and left facing bars. The only option is to use the "Ask Bid Difference Bars" which uses the absolute value of the difference to form the bars. Refer to the information here:
Numbers Bars: Numbers Bars Background Types
