Date/Time: Sun, 24 Nov 2024 13:49:43 +0000
Chart DOM sizing & spacing
View Count: 192
[2024-05-24 00:26:50] |
User509187 - Posts: 22 |
Tried to adjust a lot of settings and can't seem to get the chart DOM set to work with my chart. Using a 5M chart and the DOM on the chart is only readable if I really zoom in the chart, but I like to keep a wide view even on the 5M. I have attached a screenshot of the chart DOM with my regular DOM beside for reference. Please advise if it is possible to set the chart DOM scaling and sizing so it jives with my chart. Thank you https://www.sierrachart.com/image.php?Image=1716510382333.png |
[2024-05-24 14:12:39] |
We are not sure exactly what you are wanting to do. In general, what you are seeing is simply due to the range of the data. For the most part, it is what it is. You can expand your bar spacing, so you do not have the large range of data showing at one time, which will help with being able to view the DOM. One other option is to combine the Market Depth Data so you only get a value every number of ticks. Refer to the following settings: Chart Settings: Market Depth Combine Increment in Ticks (Chart >> Chart Settings >> Market Depth menu) Chart Settings: Apply Combine Increment in Ticks to Recent Bid/Ask Volume Columns (Chart >> Chart Settings >> Market Depth menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
