Date/Time: Sun, 24 Nov 2024 13:37:13 +0000
Crypto
View Count: 321
[2024-05-23 21:11:05] |
User749040 - Posts: 37 |
Hello SC Support, I have two questions regarding crypto 1. Do you plan to add data for Bybit? I believe the Bybit orderflow is better than Binance. 2. Do you plan to add live trading for crypto? |
[2024-05-27 18:46:06] |
Any assistance on this?
[2024-05-27 19:16:52] |
Sierra_Chart Engineering - Posts: 17156 |
1. No there are no plans for this. 2. We are considering adding support for Coinbase but we do not know when that would be. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-30 10:29:03] |
User931541 - Posts: 17 |
The version of TradingView that is available at Coinbase Advanced is more for playing. Coinbase with Sierra Chart would be a completely different quality! |
