Date/Time: Sun, 24 Nov 2024 14:10:39 +0000
VWAP settings
View Count: 205
[2024-05-23 20:46:31] |
VLiviu - Posts: 223 |
Hi all, Can you please tell me if my VWAP settings are correct? I am not sure about the STD Deviation calculation method settings. Screenshoot included Thanks |
[2024-05-24 13:43:45] |
We really can not tell you if they are correct, it depends on what you are wanting to do. All of the information for the study is at the following link, including the math for the different Standard Deviation Bands Calculation Methods: Volume Weighted Average Price (VWAP) with Standard Deviation Lines For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
