Date/Time: Mon, 16 Sep 2024 19:20:31 +0000
Exporting Sierra Data to CSV
View Count: 223
[2024-05-23 13:26:00] |
PS - Posts: 36 |
Is it possible to export the data I see on my chart (price data as well as indicators I have plotted) into a CSV? Context: I want to do some machine learning / feature engineering work using various indicators I have in Sierra, find strategy parameters, and then test those in Sierra. Creating ML Models in Sierra Chart seems cumbersome, and I think it would be easier to export the data, discover the relevant strategy parameters using ML models in a Jupyter Notebook or something, and then write that strategy back into Sierra. Please let me know if this is possible or if you have a better idea. Thank you very much in advance for your guidance. |
[2024-05-23 14:49:06] |
John - SC Support - Posts: 34453 |
Refer to the following: Edit Menu: Edit >> Export Bar and Study Data to Text File Write Bar and Study Data To File For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
