Date/Time: Sun, 24 Nov 2024 14:13:43 +0000
Alerts Based On Drawings - Can I Save Settings?
View Count: 202
[2024-05-23 13:16:55]
User261655 - Posts: 28
Hi, I've been creating alerts based on drawings using the steps below (pulled from an old support board post). Is there a way to save my preferred settings so that I don't have to repeat these steps for every alert? Thanks!
Steps:
-Create Drawing, Select "Alerts"
-Click "Enable Alert for Chart"
-Select "Last"
-Select "Above" or "Below"
-Select Alert Number
-Select "Only Trigger Once"
[2024-05-23 14:46:35]
Refer to the following:
Chart Drawing Tools: Configuring a Default Chart Drawing Alert Condition
[2024-05-24 11:51:48]
Thanks so much, John, this answered my question.
One follow-up: Is there a way to manage existing drawings-based alerts? I can see them in the alert log, but can't figure out how to turn off or delete without removing the actual drawing.
Thanks again!
[2024-05-24 15:04:35]
Select the "Alerts" option for that drawing, which will bring up the Alerts window, then select the option at the top for "Enable Alert for Chart Drawing" to remove the checkmark which "turns off" the alert for that drawing.
There is only 1 alert option for any drawing, so it is either on or off.
