Date/Time: Wed, 14 Oct 2026 08:02:22 +0000
Order window does not open
View Count: 524
| [2024-05-23 12:51:29] |
| User388924 - Posts: 2 |
Dear Sierra Cahrt team, I updated my Sierra Chart to latest version and now my Trade Window does not open anymore. Only when I open it attached on the left side of the chart. I already tried: "Window" --> "Reset Windows" but this also does not work. Thanks for your help. Best Philipp |
| [2024-05-23 14:41:56] |
| John - SC Support - Posts: 48196 |
In this particular case (the Trade Window), you need to select "Chart >> Reset Child Windows". Refer to the following: Chart Menu: Reset Child Window (Chart menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
