Date/Time: Sun, 24 Nov 2024 13:27:00 +0000
[User Discussion] - FVG
View Count: 890
[2024-05-23 11:54:41] |
SafSaf - Posts: 89 |
hi lads, i've set a study overlay to copy an fvg study from one time frame chart to another but its not working. can fvg's be copied over?
[2024-05-23 14:36:00] |
What study is "FVG"? We do not have a study with those initials. If this is a User-Contributed study, then we can not say, as we did not create those. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-23 14:43:55] |
yes it's one you recommended on one of your replies to another user on the board. it was created by gc5150/user studies
[2024-05-23 15:03:33] |
This is not our study, so we can not say anything about how it works. You would either need to ask the developer or see if someone else has any information about it. We have set this as a User Discussion. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-24 00:46:57] |
gcUserStudies - Posts: 106 |
The main setting for this is "Allow copy to other charts" for both FVG Up and Down in the study settings. Then if that is set to yes, also need to make sure the charts are all on the same instance of Sierra. if none of that works... what time frame are you copying from? |
[2024-05-25 21:44:44] |
Erguvan Ozbek - Posts: 13 |
Hi Guys, how can i add fvg indicator to my sierra chart? would you please help? Thank you
[2024-05-26 06:03:09] |
thanks GC, and thanks for the study in the first place. i want to ovrlay the monthly over the weekly over the daily over the 4hr for example? |
