Date/Time: Wed, 27 Nov 2024 08:40:43 +0000
Using two PC. setting and systems in common
View Count: 950
[2014-08-19 14:42:04] |
bercor - Posts: 30 |
Good Morning ... I have used so far SierraCHarts on a single PC .... I installed Sierra charts on a second PC but despite me connect with my USERNAME and My PSW .... I do not have the graphics and settings that I created on 'other pc .... how do I use them in the second PC? Thank you! |
[2014-08-19 15:29:52] |
Refer to help topic 15 here: Http://www.sierrachart.com/index.php?page=doc/helpdetails15.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
