Date/Time: Mon, 16 Sep 2024 20:08:54 +0000
AMP DATA FEED
View Count: 158
[2024-05-23 08:52:48] |
User901942 - Posts: 3 |
Hello, How can i get the AMP DATA fEED THROUGH DATA/TRADE SERVICE settings? Do i have to contact AMP FUTURES to get the data feed? Thank you |
[2024-05-23 14:12:38] |
John - SC Support - Posts: 34457 |
To begin with, you are on a trial, and you are not able to connect to data/trade services while on a trial. To be able to connect to data/trade services, you need to be on one of the "Integrated" packages. Refer to the following: Description of Service Packages and Pricing: Integrated Packages The next item with regards to getting real-time data is that it depends on what order routing service you are connecting to and what data you are wanting. In particular, with AMP, you would either be setup with CQG or Teton for your order routing. We do not have support for CQG data for the CME Group and EUREX, so you would have to get that data from us. Other CQG data you can use with Sierra Chart. If you are using the Teton Order Routing Service, then that is our trading service, therefore you need to get your data from us. Refer to the following information regarding our Denali Exchange Data Feeds, and note the sections for the instructions for the exchanges on the page: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
