Date/Time: Sun, 24 Nov 2024 15:59:10 +0000
Tool config feature
View Count: 168
[2024-05-22 12:13:00] |
User123458 - Posts: 3 |
Is there a hot key or some way to switch between tool configs without haveing to open tools menu and clicking curent tool config?
[2024-05-22 14:50:20] |
You can setup Control Bar buttons and/or Keyboard shortcuts to select a specific Configuration number. You can also setup Control Bar buttons to select a tool and tool configuration at the same time. Refer to the following: Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
