Date/Time: Mon, 16 Sep 2024 19:14:00 +0000
How to setup buy and sell columns of DOM in one column
View Count: 159
[2024-05-22 00:42:21] |
jsandlan - Posts: 36 |
I currently have a Trading DOM set up that has one column on the left of the price ladder for buy side orders and an additional column on the right side of the price ladder for sell side orders. There are two columns. How do you change the layout so that the buy and sell orders are in one vertical column? I have attached a screenshot of what I currently have set with two separate columns and a screenshot of how I would like to set it up with one column. Thanks! Date Time Of Last Edit: 2024-05-22 00:44:08
two-column-DOM.png / V - Attached On 2024-05-22 00:39:38 UTC - Size: 59.84 KB - 43 views single-column-DOM.png / V - Attached On 2024-05-22 00:39:51 UTC - Size: 76.02 KB - 50 views |
[2024-05-22 13:37:35] |
John - SC Support - Posts: 34452 |
You can have a single column for the Bid/Ask Market Depth by adding the "Combined Bid/Ask Size" column, but this will then be a third column, as you will still have separate Buy and Sell columns. Refer to the following: Global Trade Settings Windows: Combined Bid/Ask Size - Left/Center/Right Aligned If you do not need/want the Buy/Sell columns, then you can make those go away by turning off the option for "Trading Chart DOM On" and then turning on the option for "Show Market Data Columns". Note that this is only true for a Chart - a Trading DOM has to have the Buy/Sell columns. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
