Date/Time: Wed, 25 Dec 2024 02:17:59 +0000
Ice brent symbols with rithmic
View Count: 1488
[2014-08-19 12:57:50] |
User021827 - Posts: 174 |
I cannot get the Ice brent energy instruments with rithmic connection. Ice Russell is there, but no energy instruments. It is through AMP futures and they said they contacted Sierra to make sure they were available. I noticed a new symbol after resetting symbol list. BRN FMV0014!-ICE October 2014, but it says error symbol unknown and nothing happens. regards Shane Date Time Of Last Edit: 2014-08-19 13:01:17
[2014-08-19 15:14:12] |
We will contact Rithmic about this. This is a valid symbol. Make sure your Rithmic account is authorized for the ICE exchange. This is different from NYBOT. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-19 15:27:40] |
Rithmic has said that ICE UK is unavailable on their system. So this market is not available on the Rithmic system. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-19 15:28:10
[2014-08-19 15:55:57] |
User120827 - Posts: 77 |
Oh ok, Thank you for checking that for me. I wondered why Russell is available. But that is not ICE UK I believe. That explains that. thanks again regards |
[2015-10-26 03:07:21] |
Futures Operator - Posts: 239 |
Are there other traders here using Rithmic who would like access to Brent energies? Have been wanting this for a long time, and if there are others, would like to let Rithmic know.
[2015-11-13 21:02:08] |
We really think CQG and CTS T4 are better choices than Rithmic. You should consider using one of those instead. You will have access to ICE Europe with those trading platform services. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-13 21:02:31
[2015-11-13 21:57:34] |
User11942 - Posts: 298 |
It doesn't make any sense if you let the Rithmic know or not. Jonathan (when asked) said ICE won't allow those markets to be available thru Rithmic (apparently for free). And yes, CQG and CTS both have ICE UK data feed and you can trade all the symbols. I do thru CQG. No any problems with trading and data. Just be careful with your position size, many brokers have significantly higher house margins for ICE UK contracts.
[2015-11-13 22:19:38] |
Thank you for the information.
