Date/Time: Fri, 26 Apr 2024 07:46:10 +0000
false order line
View Count: 1409
[2013-05-07 14:34:04] |
M5amhan - Posts: 468 |
this order does not exist but it is still showing on the chart
[2013-05-07 16:21:55] |
Select Trade >>Refresh Trade Data from Service. It will be removed within 45 seconds. If not, then reconnect to the data feed because the server is still reporting it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
