Date/Time: Sun, 24 Nov 2024 15:25:03 +0000
Volume by Price
View Count: 177
[2024-05-21 18:51:21] |
User213504 - Posts: 69 |
I haven't used the study in a while and when I tried to apply it today the results were not pretty(on a daily chart the bars are not proportional). Unfortunately I saved it to a default setting and I don't remember what I changed. I would like to reset all the setting to the original. Is there any way I can get a list of the original settings? And I just had a thought, it would be a good idea to be able to save the study as different versions, i.e. a Daily, a bar, etc.
[2024-05-21 21:17:45] |
To reset a study to the system default after you have saved your own defaults, follow these instructions: Chart Studies: Resetting Default Study Settings For an Individual Study Also, keep in mind that Volume by Price profiles on an Historical Daily Chart are not going to look good due to the lack of data. Refer to the following: Volume By Price Study: How Volume by Price is Calculated for Historical Daily and Higher Timeframe Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-22 02:32:02] |
Thanks again. The second link was what I missed.
