Date/Time: Wed, 27 Nov 2024 08:26:37 +0000
Eurex / Dax session times
View Count: 1298
[2014-08-19 12:52:56]
User120827 - Posts: 77
When I test Dax on an automated strategy I have, it ignores the trading times and the flatten signal.
It works on all symbols at other exchanges, except those of eurex.
I tried changing all of the time zone and session time settings, but the eurex symbols completely ignore any of the time related signals.
Any ideas ?
regards
[2014-08-19 15:25:56]
Is this a trading system using the Spreadsheet System for Trading study?
When you say "trading times and the flatten signal", are you referring to a formula that is returning TRUE in one of the buy/sell columns or the Flatten and Cancel cell, but there is no order submitted?
[2014-08-19 15:31:46]
It is ACSIL code.
I converted it from a spreadsheet study. The spreadsheet study is giving the correct signals on Dax instrument. I am running same strategy on separate computers. One with spreadsheet, and other ACSIL.
Spreadsheet is working properly.
I have trading times set between 10 and 4 pm and a flatten signal at 4 pm.
ACSIL code is working properly on other symbols, but not on eurex.
[2014-08-19 15:35:00]
You need to check the return value of the function that you are calling that is not submitting an order when expected. Refer to the documentation here:
http://www.sierrachart.com/index.php?page=doc/doc_ACSILTrading.html
You will need to debug the problem
[2014-08-19 15:47:15]
User021827 - Posts: 174
ok, thanks
will check it out
regards
