Date/Time: Mon, 16 Sep 2024 19:15:50 +0000
Fat markers
View Count: 150
[2024-05-21 09:32:51] |
User311344 - Posts: 138 |
Some of markers in studies drawstyle are strangely "fat" - for example cross, plus as in pic. Is there any setting to make it correct? No OpenGL. Thanks.
[2024-05-21 14:55:38] |
John - SC Support - Posts: 34453 |
The size is controlled by the "Width/Size" for the subgraph that is drawing that item. You will want to lower the value to make the marker "thinner". Refer to the following: Chart Studies: Subgraphs Tab >> Line Width For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-21 18:43:27] |
It doesnt make it thinner only smaller but still fat. Especialy when chart zoom is low (2-3x). It starts having quite right proportions with chart zoom over 20x. At 2-4x it's just unrecognazible blip.
[2024-05-21 21:08:55] |
Please get us an image of the two situations (we do not know what you mean by zoom, but we need the "low" and "high" zoom) and we need to have the images taken per the following instructions, as we need to see the entire chart: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
