Date/Time: Sun, 24 Nov 2024 15:40:23 +0000
Downloaded Sierra Chart Demo problems with loading charts and DOM
View Count: 157
[2024-05-21 08:01:47]
User571972 - Posts: 1
I downloaded the demo everything is working it is showing that it is in the green and connected but when I try and open Charts or Doms they are not populating with the current prices, Charts are empty and Doms are all at 0.00
Can you help?
Thank you
[2024-05-21 13:07:56]
Sierra_Chart Engineering - Posts: 17156
Your account has been activated and the usage time extended if necessary.
If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu.
To get started with Sierra Chart, follow the Sierra Chart setup instructions here:
Sierra Chart Setup Instructions 1
After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit".
