Date/Time: Sun, 24 Nov 2024 15:41:32 +0000
Price threshold alert v2 volume threshold not working
View Count: 216
[2024-05-20 19:41:14] |
turbocapital - Posts: 21 |
Hello, I want to see lines when ask volume bid volume diagonal ratio exceeds a percentage threshold and I can do that successfully with "Price threshold alert V2". However, I'm seeing a little bit of noise from low volume sessions. I want to filter these lines with a volume threshold. I've tried to set "Volume Threshold" and "Additional Volume Threshold" but they don't do anything. What am I doing wrong? |
Screenshot 2024-05-20 224004.png / V - Attached On 2024-05-20 19:40:33 UTC - Size: 82.71 KB - 46 views |
[2024-05-20 22:04:53] |
The only time you can do a comparison of two separate items with the "Volume at Price Threshold Alert V2" is for Bid Volume and Ask Volume when the "Comparison Method" is set to "Bid Volume and Ask Volume Separately". Refer to the following: Volume at Price Threshold Alert V2: Inputs For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-21 14:18:40] |
Okay. Is the source code for this study available? I'm guessing it would take very short time to add such feature and it would be very useful.
[2024-05-21 15:04:28] |
The study source code is in the file Studies8.cpp in the ACS_Source folder under your main Sierra Chart installation folder. Refer to the following: How to Build an Advanced Custom Study from Source Code For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
