Date/Time: Sat, 13 Sep 2025 04:46:08 +0000
[Programming Help] - Trying to OR(AND a condition and I think I'm wrong.
View Count: 519
[2024-05-20 16:40:57] |
C_Money - Posts: 83 |
On my "Color bar based on alert condition" study, I want to have either condition be true, but not both at the same time: 1. Divergence detector has an up arrow on the current bar and Heiken-Ashi bar is green 2. Divergence detector has an up arrow on the current bar and Heiken-Ashi bar is a very skinny doji with just a small amount of body. This is what I have and I think it's wrong because I keep getting alerted on bars that are not doji at all: =OR(AND(ID27.SG4>0,ID18.SG4>ID18.SG4[-1]), AND(ID27.SG4>0),(ABS(ID18.SG1[-1] - ID18.SG4[-1]) / (ID18.SG2[-1] - ID18.SG3[-1]) <.50))
ID27.SG4 = divergence detector up arrow ID18.SG1 = Heiken Ashi Open ID18.SG2 = Heiken Ashi High ID18.SG3 = Heiken Ashi Low ID18.SG4 = Heiken Ashi Close |
[2024-05-20 17:41:42] |
emmanuel - Posts: 63 |
You're looking for an XOR operator, which I don't see available in Sierra Chart's formulas. You can do some research on XOR to learn how it's constructed, and from that you can troubleshoot your formula. https://en.wikipedia.org/wiki/XOR_gate |
[2024-05-20 18:43:03] |
Sorry, now that I think of it. If they are both true at the same time, then that's fine. Do I still need an XOR for that?
[2024-05-20 18:45:14] |
ForgivingComputers.com - Posts: 1118 |
As was mentioned by @emmanuel, you are looking for Exclusive OR (XOR: either is true, but not both). XOR(a,b) = (a && !b) || (!a && b)
a = AND(ID27.SG4>0,!(ID18.SG4>ID18.SG1))
Since this cannot be a Green Bar, the Doji is either Open=Close, or Open>Close. b = AND(!(ID27.SG4>0, ID18.SG4<=ID18.SG1)),(ABS(ID18.SG1 - ID18.SG4 <.50))
[2024-05-21 00:44:41] |
Sawtooth - Posts: 4263 |
Here's another example: Need a alternative for =XOR |
