Date/Time: Sun, 24 Nov 2024 14:57:54 +0000
I cant move my charts up and down with the mous
View Count: 183
[2024-05-20 16:19:34] |
T2tradesLLC - Posts: 1 |
I cant move chart up or down. I can only move it left and right.
[2024-05-20 16:20:13] |
We assume you are using the "Hand" tool. In which case, refer to the following setting: Chart Drawing Tools: Support Vertical Scaling/Movement With Hand Tool (Global Settings >> Tool Settings >> General >> Tool Options) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
