Date/Time: Sun, 24 Nov 2024 14:30:51 +0000
how can i change the font size of the chart
View Count: 190
[2024-05-20 15:43:18] |
Veleskie - Posts: 8 |
how can i change the font size of the chart i go to your section tutorial but it thats get fix
Screenshot 2024-05-20 084009.png / V - Attached On 2024-05-20 15:43:13 UTC - Size: 112.57 KB - 43 views |
[2024-05-20 17:42:28] |
Refer to the following setting: Graphics Settings: Chart Text - (current font name) Also, make sure you understand that this can be changed globally or for individual charts. If a chart is not setup to use the Global Settings, then you will need to make the change for each chart individually. Refer to the following: Graphics Settings: Using Different Color and Graphics Settings for Specific Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
