Date/Time: Sun, 24 Nov 2024 14:57:50 +0000
a message, which repeats itself over and over without stopping
View Count: 181
[2024-05-20 10:13:14] |
User285770 - Posts: 41 |
I receive a message, which repeats itself over and over without stopping, very quickly, I can hardly read because it is so fast... What should I do? I attach screenshots |
image_2024-05-20_13-01-35.png / V - Attached On 2024-05-20 10:12:18 UTC - Size: 437.3 KB - 53 views image_2024-05-20_13-01-56.png / V - Attached On 2024-05-20 10:12:27 UTC - Size: 417.62 KB - 50 views |
[2024-05-20 14:48:35] |
When using Rithmic you cannot use invalid symbols. You must remove all of them which do not follow the Rithmic format. Instructions: Chart Data and Chart Data Files: Cleaning Up Old and Unused Symbols for Efficiency For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
