Date/Time: Wed, 27 Nov 2024 10:51:37 +0000
Barchart data provider still used?
View Count: 1223
[2014-08-19 03:43:46]
User148824 - Posts: 10
I once used barchart data through sierra charts, do you still offer this?
I liked the volume bars for stocks that the data allowed me to see. For example, each bar was 10,000 shares traded.
If there is no more barchart, what is the alternative to get the volume bars?
Thank you.
[2014-08-19 04:42:15]
This is still supported. Refer to this page here:
https://www.sierrachart.com/index.php?page=doc/Barchart.com.php
However, you can use the Sierra Chart Real-time and Historical Exchange Data feed for US stock data:
Sierra Chart Exchange Data Feed
[2014-08-22 03:02:01]
Thanks.
I just ordered the data.
However, I can't seem to be able to download stock data?
When I go File - Find Symbol - Stocks ...there are no stocks there.
I also just try to go File - New Symbol - and type in a stock and nothing comes up..
I am connected to the data feed.
Here is the log copied:
Software version: 1174 | 2014-08-22 02:55:40
Usage end date: 2014-09-22 | 2014-08-22 02:55:40
Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2014-08-22 02:55:40
Received 1 data feed usernames. | 2014-08-22 02:55:40
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-08-22 02:55:40
Active service: SC Exchange Data | 2014-08-22 02:55:40
Time Zone: +00:00:00 (UTC+00) | 2014-08-22 02:55:40
2014-08-21 22:55:40 Local computer clock time | 2014-08-22 02:55:40
2014-08-22 02:55:40 GMT time | 2014-08-22 02:55:40
2014-08-22 02:55:40 Time zone adjusted time | 2014-08-22 02:55:40
Time difference to server time: 3 seconds. | 2014-08-22 02:55:40
Program path: C:\SierraChart\ | 2014-08-22 02:55:40
Data Files path: C:\SierraChart\Data\ | 2014-08-22 02:55:40
OS Version Number: 6.1 | 2014-08-22 02:55:40
Checking for new symbol settings for scbcd | 2014-08-22 02:55:40
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 188.40.121.148 | 2014-08-22 02:55:40
HTTP connection to www.sierrachart.com:80 (1372) | Connected. | 2014-08-22 02:55:40
Symbol settings are up-to-date for scbcd | 2014-08-22 02:55:40
SC Exchange Data | Connected. | 2014-08-22 02:55:44
HTTP connection to www.sierrachart.com:80 (1372) | Closed. No error. | 2014-08-22 02:55:50
HTTP connection to www.sierrachart.com:80 (1372) | Shutdown and closed. | 2014-08-22 02:55:50
Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\aapl.scid | 2014-08-22 02:58:50
SC Exchange Data | Starting real-time market data updates for: AAPL. ID: 1 | 2014-08-22 02:58:50
SC Exchange Data | Subscribing to market data in the service client is not supported. Symbol: AAPL | 2014-08-22 02:58:50
Intraday data recording state for symbol AAPL is set to pending. | 2014-08-22 02:58:50
HD Request # 2 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: scbcd | 2014-08-22 02:58:50
Compressing file: C:\SierraChart\Data\AAPL.scid. This may take a while. | 2014-08-22 02:58:50
HD Request # 2 | Download start Date-Time: 2014-02-17 02:58:50.0 | 2014-08-22 02:58:50
HD Request # 2 | Using server: scdf1.sierracharts.com port 10149 | 2014-08-22 02:58:50
Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-08-22 02:58:50
Socket (2552) | Connected. | 2014-08-22 02:58:50
HD Request # 2 | Sending historical data logon request message. | 2014-08-22 02:58:50
Socket (2552) | Shutdown and closed. | 2014-08-22 02:58:50
The network socket for historical data has been closed. | 2014-08-22 02:58:50
HD Request # 2 | Error downloading historical Intraday data for AAPL. Historical data logon error: Invalid/missing data for service code: scbcd | 2014-08-22 02:58:50
HD Request # 2 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for AAPL | 2014-08-22 02:58:50
HD Request # 2 | Intraday download COMPLETE for AAPL. Completion time: 0s | 2014-08-22 02:58:50
Real-time Intraday chart data file updates started for AAPL | 2014-08-22 02:58:50
The chart image has been saved to: C:\SierraChart\Images\AAPL 1 Min #1 2014-08-22 03_00_33.717.png | 2014-08-22 03:00:33
[2014-08-22 05:11:17]
Go to this page:
https://www.sierrachart.com/usercp.php?page=SC_RealTime_DataFeed_SetExchanges
Sign the exchange agreement that is linked to and enable the US equities exchange.
[2014-08-22 10:13:58]
After you complete the exchange agreements, be sure to go back to this page and reload it:
[2014-08-22 11:08:57]
Does one have to pay 10.5 for USA equities even if I don't need live data...
[2014-08-22 16:41:10]
Confirm if you do not need real-time data.
In this case you do not need the Sierra Chart Real-time and Historical Exchange Data Feed.
All you need is the Sierra Chart Historical Data Service which is included with Service Package 3:
Let us know and we will change your Service Package to 3 and we will cancel the Sierra Chart real-time data feed for you.
[2014-08-22 16:42:38]
Thx.
I need tick data for stocks, I like using charts with volume bars...i.e. 1 bar = 10,000 shares
[2014-08-22 16:42:57]
but I don't need it real time.
[2014-08-22 17:30:01]
In this case you do not need to activate the US equities exchange.
You will still be able to get historical data. We need to add support for this. This will be out in version 1177 coming out later today.
As long as you have activated the Sierra Chart Exchange Data Feed, and you have, and the Service in Sierra Chart is set to "SC Exchange Data" , you will be able to get historical tick by tick data for stocks with this new release.
Date Time Of Last Edit: 2014-08-22 17:31:59
[2014-08-23 13:53:39]
I still don't see 1177..where is it?
[2014-08-23 17:40:32]
We will try to get it out today.
[2014-08-24 22:54:15]
There is a problem with version 1177. You need to update to version 1178. We apologize for that.
1177 has been locked out.
