Date/Time: Sun, 24 Nov 2024 13:52:52 +0000
Ability to change to more reliable servers for a asia (Taiwan) connection?
View Count: 194
[2024-05-19 13:18:35] |
User735389 - Posts: 189 |
I remember a long time ago i was having sporatic data connection issues with asia. At that time it was suggested i change servers to something closer to my locations. I can't seem to find those related setitings, not sure if its been removed or i'm mis remembering. I'm currently using the All Services for forex / cfd data. along with delayed futures data, but that's not as important.
[2024-05-24 18:54:38] |
Sierra_Chart Engineering - Posts: 17156 |
We are asking you to wait about two weeks, when we are going to add a new ISP and we want to see if that helps.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-05-24 18:54:56
