Date/Time: Sun, 24 Nov 2024 14:27:24 +0000
Divergence Detector study could not creat a Candlestick Bar Divergence
View Count: 185
[2024-05-19 09:59:39]
User669552 - Posts: 15
I want the Divergence indicator to show me a arrow when Delta in The Numbers Bar calculated Values study is positive but the there is a red candlestick and vice versa show me an arrow when the candle stick is green (upwards candle) but there is negative Delta in the Numbers bar calculated values study. I want the arrow to point those candle. Sierra chart is not giving me those options. How do I achieve that.
[2024-05-19 15:13:24]
We need you to post on the Support Board with your active Sierra Chart account. To do that select "Help >> Support Board " from within Sierra Chart.
If you did not get an answer to your prior question, post here again after doing the above confirming that you have logged in with your current account to let us know.
