Date/Time: Sun, 24 Nov 2024 14:25:08 +0000
Price Range (Candlestick Bar) at specific time daily for a specified date range
View Count: 197
[2024-05-18 20:37:27] |
User130696 - Posts: 88 |
Hello, Is there a way to plot a chart with Candlesticks at a specific time daily for the specified date range? You can visualize a chart like the one below, where the time of day is fixed, but Candlesticks, shown by a stack of bars, vary in size according to the actual range at that time for a specified date range/period. Please see the screenshot as below characters are jumbled up. | | | | | | | | | | May 1 10 AM, MAY 2 10 AM, MAY 3 10 AM....... April 1 10 AM.... Date Time Of Last Edit: 2024-05-18 20:39:55
Screenshot 2024-05-18 at 4.38.47 PM.png / V - Attached On 2024-05-18 20:39:20 UTC - Size: 117.67 KB - 54 views |
[2024-05-19 14:50:57] |
We are not really understanding what you are wanting to do. You can use the "True Range" study to get the range of the bars. Refer to the following: True Range And then you can manipulate that data as you want. It sounds like the "Relative Volume" study may give you what you want, if you are wanting the accumulated range for a specific time every day. Refer to the following: Relative Volume For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
