Date/Time: Sun, 24 Nov 2024 15:07:07 +0000
Chart time Frame will not change
View Count: 195
[2024-05-18 18:19:58] |
User577660 - Posts: 9 |
I duplicated a 4H chart to another chartbook. But it will only duplicate as a 5M chart. When I try to then change it to a 4H chart, it re-calculates briefly (for a split second) to the 4H, but then resumes re-calculating and will only default to a 5M chart. No matter home many methods I use to try and change it from a 5M to a 4H(or 240M), it will not let me.
[2024-05-19 14:31:43] |
Refer to the following: Unable to Change the Bar Time Period for Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
