Date/Time: Sun, 24 Nov 2024 14:41:45 +0000
Polish index WIG or WIG-20
View Count: 178
[2024-05-18 12:37:24] |
User266447 - Posts: 253 |
Is it possible to get access to 1) The Polish Index WIG or WIG-20? 2) Can I find German 2 year bond - SCHATZ? 3) Is it possible to overlay a chart? For example OPEN sp500 CHART AND PUT a different chart on it i.e DAX? |
[2024-05-19 14:27:42] |
1) We do not have this data. You would need to see if your Trading Service has this available. Another option for charting this data only would be to see if IQ Feed has the data. Refer to the following: DTN IQ Feed Data Service 2) Same answer as #1 above. 3) Yes, refer to the following study in particular: Add Additional Symbol For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
