Date/Time: Sun, 24 Nov 2024 14:26:13 +0000
amp futures apex trading question
View Count: 155
[2024-05-17 19:11:13]
jasonfutures - Posts: 1
i plan on trading thru apex prop firm, (rhythmic) i was planning on getting a AMP live account for data so i dont have to pay the more expensive professional cme data.
Do i tell them i want a rhythmic account? thanks for any help
[2024-05-19 13:40:23]
With AMP, you would want to tell them you want to be setup with the Teton Order Routing Service. Follow the instructions at the following link, including the section for setting up the Denali Exchange Data Feed:
Sierra Chart Teton Futures Order Routing: Setup Instructions
Keep in mind, if you will not be connected to that AMP account at all times, then you will need to connect at least once a month for verification. Refer to the following instructions for this:
Also, be aware that you can not connect to trading/data services while on a trial. In order to be able to connect, you need to be one of the "Integrated" packages. Refer to the information on the packages here:
Description of Service Packages and Pricing: Integrated Packages
When you are ready to change to a paid package, follow these instructions to do so:
Sierra Chart Purchase and License Information: Instructions
