Date/Time: Sun, 24 Nov 2024 14:39:38 +0000
Changing the position of order line
View Count: 146
[2024-05-17 12:35:18] |
liangyu - Posts: 3 |
I'm trying to set up my DOM, but currently I'm having difficulty shifting the order line. Is there a way for me to shift it from the left of the DOM to the right empty column?
Attachment Deleted. order line on dom.png / V - Attached On 2024-05-17 12:34:09 UTC - Size: 47.56 KB - 49 views fatcat dom.png / V - Attached On 2024-05-17 12:34:16 UTC - Size: 190.06 KB - 50 views |
[2024-05-17 19:31:24] |
Sierra_Chart Engineering - Posts: 17156 |
No, that is not supported.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-05-17 19:31:29
