Date/Time: Sun, 24 Nov 2024 15:02:30 +0000
Can I display margin requirement as text in indicator?
View Count: 197
[2024-05-17 09:26:37] |
User799255 - Posts: 24 |
I know I can pull the margins of symbols by looking up in Trade->Tradeaccount/balance->manage->edit->symbol lookup But I would like it to be displayed constantly without me having to look up. Afterall, the brokers change the margin requirements frequently. Is there a way to do that? Thanks |
[2024-05-17 17:16:30] |
Sierra_Chart Engineering - Posts: 17156 |
No there is no other place this can be done. And margins should not change frequently. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-05-17 17:16:37
