Date/Time: Sun, 24 Nov 2024 14:40:47 +0000
Enable multiple Entries in same direction
View Count: 273
[2024-05-17 05:48:09] |
pkhst958 - Posts: 57 |
I have set in study settings "allow multiple entries in same direction" to yes. Though, some bars bars after the first entry the second entry was only shortly shown with an arrow pointing upwards in the chart, but not executed. A margin limit was not the reason for not executing. What else coul I try to have the second entry executed next time?
[2024-05-17 14:55:08] |
Sierra_Chart Engineering - Posts: 17156 |
You need to check for the reason for the order submission being rejected. Refer to: Automated Trading Management: Troubleshooting Automated Trading System Behavior What is the exact method in Sierra Chart you are using for automated trading? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-05-17 14:56:17
[2024-05-17 16:07:43] |
The trade service log is interesting, though only shows today. Is it possible to show more days?
[2024-05-17 19:34:14] |
Look at the Trade Activity Log: Trade Activity Log: Viewing Historical Trade Activity Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
