Date/Time: Wed, 27 Nov 2024 08:43:08 +0000
Custom study from Visual Express
View Count: 1093
[2014-08-18 19:40:26]
User120827 - Posts: 77
hi
I created a study in MS Visual Express and it works fine with Sierra on the same computer.
But if I copy the dll to my other computer, it wont load in Sierra.
Did I miss something ?
regards
[2014-08-18 21:02:25]
What version of Visual C++ did you use?
[2014-08-18 21:07:38]
The one in your documentation: Visual C++ Express edition 2010 , the free one.
shane
Date Time Of Last Edit: 2014-08-18 21:09:59
[2014-08-18 21:47:33]
Perform an Internet search for Visual C++ 2010 Redistributable Package and install that on the computer.
[2014-08-18 22:25:15]
Loading that on other computer did not help.
trying sierra compiler.
How can I fix this error ?
"C:\SierraChart\CPPCompiler\bin\g++.exe" "C:\SierraChart\ACS_Source\shanesample.cpp" -march=i686 -mtune=i686 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -o "C:\SierraChart\Data\shanesample.dll"
C:\SierraChart\ACS_Source\shanesample.cpp:8:29: error: expected ')' before 'sc'
SCSFExport(SCStudyGraphRef sc)
thanks
shane
Date Time Of Last Edit: 2014-08-18 22:39:11
[2014-08-19 03:05:14]
Show us the actual source code at line 8 that is giving this error.
Date Time Of Last Edit: 2014-08-19 03:05:35
[2014-08-19 05:17:19]
hI
I found the problem and fixed it.
