Date/Time: Sun, 24 Nov 2024 14:22:33 +0000
Sierra Chart API Error
View Count: 431
[2024-05-17 00:01:08]
TPH_Main - Posts: 13
I am receiving "Error: unable to verify the first certificate" when adding/removing users to custom study groups. I am checking now to see if the error is on my end, but I haven't changed anything.
[2024-05-17 00:17:01]
Same error on local machine trying to make requests as well.
Thanks!
[2024-05-17 05:31:05]
Sierra_Chart Engineering - Posts: 17156
We do not see this ourselves. We did update a security certificate. Try restarting your browser and clearing your browser's cache.
[2024-05-17 11:47:47]
The control panel on Sierra Chart works fine for adding/removing users. The API no longer works. I am still having the same error this morning.
[2024-05-17 13:01:08]
User907968 - Posts: 823
Same problem for me also.
[2024-05-17 13:39:18]
You are referring to the API itself. Not the webpage. We will check on that.
[2024-05-17 16:03:52]
Sierra Chart - Max - Posts: 5730
How are you accessing the api?
Sierra Chart Support
[2024-05-17 16:17:22]
I get errors making the request locally on Postman (just a way to send requests) as well as through my automated implementation running on a server.
[2024-05-17 16:23:00]
obviously changed the variables
curl --location --request POST 'https://www.sierrachart.com/API.php?AdminUsername=enterusername&AdminPassword=enterpassword&Service=CustomDLLStudiesManagement&SCDLLName=TPH%20Custom%20Studies&Action=add&UserSCUsername=entergiveusername'
[2024-05-17 16:48:46]
We have tested curl, and we do not see the stated issue. Can you confirm that your computer clock is set correctly?
curl -I 'https://sierrachart.com/API.php'
HTTP/2 200
content-type: text/html; charset=UTF-8
date: Fri, 17 May 2024 16:44:01 GMT
server: Apache
x-content-type-options: nosniff
x-frame-options: sameorigin
x-xss-protection: 1; mode=block
curl 'https://sierrachart.com/API.php'
ERROR: Call not supported. Contact Sierra Chart support (support@sierrachart.com) for help with this.⏎
curl -V
curl 8.4.0 (x86_64-apple-darwin23.0) libcurl/8.4.0 (SecureTransport) LibreSSL/3.3.6 zlib/1.2.12 nghttp2/1.58.0
Release-Date: 2023-10-11
[2024-05-17 17:00:35]
We do see that there was an issue with the following version of curl 7.81.0.
So at the moment we have reverted to the older cert which fixes the issue. We will need to see why the new certificate does not work with older version of curl.
[2024-05-17 17:02:03]
Yes it is.
- I should clarify that when running curl from terminal the error is actually
"ERROR: SCDLLName not set"
but it very clearly is set.
When i make the request in Postman you can see the certificate error (attached image) which is also what the implementation on the server returns.
Private File
[2024-05-17 17:12:21]
The curl command in post 9 is not setting the SCDLLName properly. Note the the documentation specifies it to be sent as a post, but you are sending it as a get (part of the URL).
To send data as a post you need to use -d with curl
https://curl.se/docs/manpage.html#-d
Date Time Of Last Edit: 2024-05-17 17:22:01
[2024-05-17 17:14:18]
Thank you, working again for me (via curl).
[2024-05-17 17:20:15]
Working for me as well. Thanks
[2024-05-17 17:22:23]
User719512 - Posts: 263
To add on here, there are API errors from Python as well where requests does not work, but urllib3 does. requests gives SSL errors unless you turn off verify (strongly discouraged of course!).
NOTE: looks like your form/site is trying to make the "CODE" with a Sierra URL into a link.
previously worked now broken:
with requests.Session() as session:
for sierra_dll in sierra_dlls:
if True:
url = 'https://www.sierrachart.com/API.php'
payload = {
'AdminUsername': username,
'AdminPassword': password,
'Service': 'CustomDLLStudiesManagement',
'SCDLLName': sierra_dll,
'Action': 'GetAllUsersForDll'
# Use the post method to send a POST request
!!!broken
response = session.post(url, data=payload)
!!!workaround
response = session.post(url, data=payload, verify=False)
this code works and must use some different cert chain verification:
http = urllib3.PoolManager()
resp = http.request(
'POST',
'https://www.sierrachart.com/API.php',
fields={
'AdminUsername' : username,
'AdminPassword' : password,
'Service' : 'CustomDLLStudiesManagement',
'SCDLLName' : sierra_dll,
'Action' : 'GetAllUsersForDll',
json_data = json.loads(resp.data)
