Date/Time: Sun, 24 Nov 2024 15:57:32 +0000
Use Global Graphics Settings Instead of These Settings won't stay uncheck
View Count: 148
[2024-05-16 22:57:43] |
teyong - Posts: 3 |
Somehow I have to go back to uncheck the 'Use Global Graphics Settings Instead of These Settings' under Graphics Settings - Chart from time to time. It's been annoying that the setting won't stay. This happens randomly, sometimes I uncheck it and 5 min it will be uncheck automatically, sometimes 30 min, and sometimes 1 hr. The reason I need this is because I do bar overlay so that I can see a candlesticks in the middle of the numbers bar. Any ideas how to fix it? Or maybe adding an option to overlay candlesticks in the numbers bar so that I don't need 2 indicators.
[2024-05-17 05:24:13] |
Sierra_Chart Engineering - Posts: 17156 |
The only reason we know this would be a problem is if that setting is changed by a custom study. Otherwise, this is not making sense.
