Date/Time: Tue, 22 Apr 2025 07:16:54 +0000
Teton and cunningham clearing
View Count: 467
[2024-05-16 21:35:29]
User783032 - Posts: 17
I have recently opened an account with cunningham clearing. I see them listed in the drop down list for Teton routing. Cunningham is not aware of why they are listed. Can you tell me if you have an agreement with cunningham and who I should contact in their support team?
[2024-05-17 06:48:46]
Sierra_Chart Engineering - Posts: 19293
Maybe you are with a different Cunningham Clearing than we are aware of.
Can you give us contact information for who you are working with at Cunningham and we will get in touch with them.
Date Time Of Last Edit: 2024-05-17 06:49:40
[2024-05-17 11:16:32]
Joseph W Castiglione
D: +1(312)470-6260
C: +1(847)977-6497
They have recently been acquired by a company named Plus500. They use a CTS T4 frontend software that references Sierra Chart integration ability but nobody seams to know how to integrate.
[2024-05-17 13:52:13]
Ok we have contacted Cunningham about this. This should be resolved shortly.
[2025-01-25 22:27:03]
mikebarrels - Posts: 8
is this the cunningham clearing that was affiliated with/acquired by plus500 futures? i see plus500 listed on the 'setup instructions' list of available clearing firms for teton order routing. i asked a rep at plus500 about this and they said the only platform you can use is theirs. i showed them a screenshot of the list that shows plus500, and i'm still waiting to hear back. thought i'd dig around the support board in the meantime. HAGW
Date Time Of Last Edit: 2025-01-25 22:31:07
imageplus500 ss.png / V - Attached On 2025-01-25 22:30:49 UTC - Size: 54.29 KB - 43 views
[2025-01-25 23:57:08]
Yes:
And you can use Sierra Chart with Plus500. They do support Teton order routing with Sierra Chart.
